Hey people, put my rolla on ULP finally has done around 180k's on it so far but it has to go in to have the timing adjusted and have a tune!
it lasted around 100k'm before any problems now it pings (rattles) under load! and takes a while to actually die when ignition is turned off (aparently called advanced ignition or timing or something), And it takes a little longer to turn over when starting but can't complain!
Seem's to have more power now,
although i have to fix the overheating problems! (will start with a new thermostat and go from there)
i know you can get your engine all warmed up, then rev it up while pouring warm water down the carb....this is an old trick taught to me.
it does work, i have personally gotten a big piece of carbon stuck in a valve seat, thus i wouldn't recommend it to anyone with piston/valve clearance issues
if you do get some thing stuck, just rev the hell outta it...it'll clear
Well, the strange thing is it only seems to happen after it's been for a long drive (ie, down the highway etc). If I just drive to the shops or whatever, it's fine. And mind you, I think it has a 4.5:1 diff or something, and a 4 speed, so going down the highway means it's revving pretty hard...
Edited by demuire
Yeah I've done 10,000km in my KE55 with a 4K-C on ULP and I can't complain
Seems to run rather well, its got the get up and go that i like
I use FLASHLUBE additive, i find it gives me a bit more billy-o and doesnt seem to run as hot and better fuel economy. Good stuff.
I only ever have the running on problem when i've been on the highway fanging it for a while. Probably to do with similar reasons to what demuire said, cept mines got a 4.11:1 diff and a Five speeder.
Still, it ain't exactly taking it easy at 130kmh.
I'm going to continue to run it on ULP.
Can't wait to get my next car though... mmm LPG... mmm 40c/Litre... mmm
Well we've changed the sparkies not too long ago, with the ones that are supposed to be for the 4K so I guess that rules that out. It doesn't appear to be running exceptionally hot or anything, so maybe it's running lean. Or has lots of carbon. Dunno. Maybe we should fix it sometime...
what if the counter wieghts are screwed up? it could overadvance as the rpm increases
also after a hot run; those little sharp edges of carbon will glow setting off the fuel
hey i havnt read the last 50 posts cos i'm 2 tired from the INFMS cruise last night we didnt get hme til 4:15 am!
ne way i had a new radiator installed the other day and since it has been running cooler it seems to be running better and turning off etc!
The temp guage hasnt left the C yet which is awwsome as it used to run on 1/2 and lately before the new radiator almost boiling!
