March 25, 200917 yr comment_331151 Can ya get a thicker head gaskets to fit a k engine ?? if so where and how much ... got to much compression need to get it down... (but can touch the pistons or modify the head) Report
March 26, 200917 yr comment_331568 Probably need to get a custom one made. I would suggest your best bet is to have some volume added to your combustion chamber, that might be more straightforward. Edited March 27, 200917 yr by philbey Report
March 27, 200917 yr comment_331738 http://www.ridgecrest.com.au/3201.html They should be able to help you out. stu. p.s. it says they can do up to 2mm thick is that going to be enough. Edited March 27, 200917 yr by kickn5k Report
March 29, 200917 yr Author comment_332220 http://www.ridgecrest.com.au/3201.html They should be able to help you out. stu. p.s. it says they can do up to 2mm thick is that going to be enough. cheers bud thankyou for ya help... Report
April 4, 200917 yr comment_334183 I've heard of guys using two head gaskets. Does anyone know if this is a usable alternative?? Report
April 6, 200917 yr comment_334454 I've heard of guys using two head gaskets. Does anyone know if this is a usable alternative?? this sounds very risky, id imagine it would blow the gasket with half the effort might be possible with metal head gasket? buy a single thicker one, with two there would be a massive soft spot. cost less in long run to buy thick gasket "but can touch the pistons or modify the head" is this supposed to be "but CAN'T touch the pistons or head"?? Edited April 6, 200917 yr by kiahn Report
