April 6, 200917 yr comment_334649 Hi everyone I just have a question about what options people suggest for my KE30. Its currently a 4 speed and i want to convert to a 5 speed and i just wondering what options i have? So far i know i can get a a k55 5 speed, I'm busying trying to find one. Or ive heard that i can get a ke70 gearbox and swap the extension housings so i don't need to swap the tailshafts. But does this mean i would need a new shifter locations. All opinions welcome Cheers Report
April 6, 200917 yr comment_334650 You don't need to swap tailshafts for a KE70 K50. Swapping the extension housing gives you a KE55 K50 shifter position. If you don't do that you need to cut a hole further back in the trans tunnel. Report
April 6, 200917 yr Author comment_334653 You don't need to swap tailshafts for a KE70 K50.Swapping the extension housing gives you a KE55 K50 shifter position. If you don't do that you need to cut a hole further back in the trans tunnel. Thas what i thought, so just to make sure I'm getting this right I can get a ke70 5 speed, swap the extensions housings so the shifter position is the same as my K40 4 speed and also the bellhousing will bolt up the same and i wont need to change the tailshaft either? Essentialy making a K50 gearbox Thanks EDIT, just on that too, will the extension housing of the K40 gearbox swap onto the KE70 box? Edited April 7, 200917 yr by nikctime21 Report
April 7, 200917 yr comment_334654 Its already a K50 gearbox...... you're just making it ke30/55 friendly. :party: Bellhousing is intergrated. Tailshaft is same spline and length. Report
April 7, 200917 yr Author comment_334655 Cool, thats what i thought. I'm just a bit new to corolla's thats all. Thanks for the help :party: lol Report
April 7, 200917 yr comment_334680 so if u get a gearbox from a ke70, rip urs out of a ke 30/55. unbolt the extension housing on both, then bolt the 30/55 housing one to the 70 5spd, you have a 5 spd that fits 30/55 with no problems??? any problems bolting the housing on or taking them off? i never knew this before. Report
April 7, 200917 yr comment_334687 so if u get a gearbox from a ke70, rip urs out of a ke 30/55. unbolt the extension housing on both, then bolt the 30/55 housing one to the 70 5spd, you have a 5 spd that fits 30/55 with no problems??? any problems bolting the housing on or taking them off? i never knew this before. Yes. You just can't swap between K40's and K50's. When re-fitting the other extension housing you just need to make sure all of the selector forks line up properly, but this isn't hard. :party: Report
