4k, How Much Oil?
Hiya, I've got a KE70 with a 4k, I'm gonna change the oil. How many litres of oil goes in there? :wink
Thanks.
enough till the dipstick says so?
put 3L in and check, top up if required when its at the full mark start it up for 20 seconds, swtich off let it sit and check again, top up as required.
Check the level of the OLD oil to make sure it's full(ish) and then drain it.
Once done, check how much oil you drained by pouring that into an old oil bottle.
Then, fill up how much you drained!
Too lazy for that thanks ;)
I don't exactly fill it on up the millilitre, just wanted to know if 4L was enough :hmm:
Edited by eiriksmil
4L is heaps. Just do what furry frog suggested and put 3L in and top up if needed.
Yeah, three litres worked like a charm really.. :hmm: Good to have some new oil in there when you're doing 600 miles a week ;)
