SLO-030 Posted May 9, 2009 Report Posted May 9, 2009 (edited) Hey guys, Was looking for some HG torque specs a while ago and i bought another HG yesterday so i though id post up the torque specs. Specs are for an ACL Ezy Fit head gasket PN BD950EZ. Specs were also the same for my ACL Mono Torque head gasket PN BD950MT Torque ALL bolts to 25Nm or 18.5Ft-Lb. Torque them ALL again to 50Nm or 37Ft-Lb. Then one last time to 65Nm or 48 Ft-Lb Ft-Lb = Foot pounds Nm = Newton meters Remember to do them all before torqueing them up more. in stages :P Torqueing sequence: 8 6 1 3 9 10 4 2 5 7 Take it for a drive around the block a few times to get it warm then torque all the bolts up to 65Nm or 48Ft-Lb again as the heat expansion will cause the bolts to loose their torque slightly. I usualy add another 5Nm when i do this. Hope this helps a few of you. CHEERS Ryan Edited May 10, 2009 by SLO-030 Quote
Taz_Rx Posted May 10, 2009 Report Posted May 10, 2009 Go put it in the FAQ/Knowledge base as all it says is "as per manufacturers specs". Maybe put a *note* saying to still check the above anyway. Quote
Boost+k Posted May 11, 2009 Report Posted May 11, 2009 don't all k series run torque to yeild bolts tho? Quote
Taz_Rx Posted May 12, 2009 Report Posted May 12, 2009 Nah Todd only 5k's have the shitty TTY bolts. 3k/4k ones are much better and re-usable. ....still no comparison to a an ARP though! :) Quote
Felix Posted May 12, 2009 Report Posted May 12, 2009 The late dished 4k's also have the TTY bolts. Quote
Boost+k Posted May 13, 2009 Report Posted May 13, 2009 Nah Todd only 5k's have the shitty TTY bolts. 3k/4k ones are much better and re-usable.....still no comparison to a an ARP though! :D good to know :jamie: Quote
shauns ke30 Posted May 22, 2009 Report Posted May 22, 2009 (edited) Added Will this help its for a 5k and it has some other goods in there cheers shaun. 5k.pdf Edited May 22, 2009 by shauns ke30 Quote
