Car Not Starting After Driving For 20 Mins
Hey everyone i have a shitty ra40 celica with an 18ru engine
2 litre carby thing
anyway i can start it and drive it for a while and then when i turn it off i wont be able to start it again, it will not have spark from the coil for about half an hour and then i can start it.
keeping in mind the timing chain is on its way out and ive never checked the timing/points
probs something i should do
anyway
any advice?
2 litre carby thing
anyway
any advice?
I remember a Dirty Wheels article from Wheels years ago where a Falcon had a similar problem, would run fine when cold but after it warmed up it would start running rough....turned out a hair-line crack in the dizzy cap was opening up when hot and causing a cylinder to drop out, maybe a similar thing is happening with you except it is the coil lead, although you'd expect it to cut out first.
