Medicine_Man Posted May 21, 2005 Report Posted May 21, 2005 (edited) You can use 4A-C engine mounts on the AW11 MR2 4AGE motor, but the passenger side engine mount will require some modification. The reason you will need to modify the mount is so that it clears the oil return sandwitch plate and lines. You will also find that you will need to hunt for some longer bolts for the engine block to gearbox mounts. You can use your origional gearbox mount and crossmember. AW11 MR2 Oil Return Line Setup Edited May 21, 2005 by Medicine_Man Quote
Medicine_Man Posted May 21, 2005 Author Report Posted May 21, 2005 (edited) Front of the 4A-C engine mount modified to clear the oil return line setup. (Angle grinder comes in handy :moon: ) Edited May 21, 2005 by Medicine_Man Quote
Medicine_Man Posted May 21, 2005 Author Report Posted May 21, 2005 Rear of the 4A-C engine mount modified to clear the oil return line setup. Quote
demuire Posted May 21, 2005 Report Posted May 21, 2005 Hmm, I'm surprised, mine clears just fine? I've got the return too (but I don't have the metal pipe that goes to the top, it just ends at the banjo) Quote
Super Jamie Posted May 21, 2005 Report Posted May 21, 2005 or you can do what travis edwards did, and make up a custom mount and use cortina rubbers. think your mounts through first though, travis has to take the engine out to change the oil filter :moon: Quote
Medicine_Man Posted May 21, 2005 Author Report Posted May 21, 2005 Why muck around with custom mounts when it takes 2 seconds to shave a few bits off some 4A-C engine mounts.. You only need to do this if you have the oil return / sandwitch plate anyway.. Quote
Super Jamie Posted May 21, 2005 Report Posted May 21, 2005 it's a bit different putting it in a ke10, the crossmember mounting points are ALOT closer together. it would even be different putting it into a ke30/55 Quote
Medicine_Man Posted May 22, 2005 Author Report Posted May 22, 2005 this thread is based on a conversion for an AE71/AE86, probably best not confusing people.. Quote
