July 21, 200917 yr comment_360248 I'm having a bit of trouble with my ke55. Sometimes during turns my wheel locks up and can't turn anymore. I can release the wheel a bit then turn without problem or just pull real hard and hear a big knock. It's like it gets stuck on one point during a turn because once I yank it past that point it turns fine again. The steering has always felt pretty heavy, but now its playing up. I havnt driven it much lately and havnt had time to jack it and check it out. from a quick read up and amatuer opinion i think it could be pitman arm. what do you guys rekon, and how would be the best way to check/test. Report
July 21, 200917 yr comment_360292 My two cents worth don't DRIVE IT ANY WHERE .more than likely the steering box shagged . Jack it up turn it from lock to lock try see where its binding. :P check oil in the steering box,just take top cover off have a look. No oil rooted ,get another one. rob Edited July 21, 200917 yr by corollaart Report
July 21, 200917 yr comment_360296 i had this problem after i fitted an aftermarket steering wheel. a pin on the column was getting stuck on a groove on the bosskit. maybe that? or does it sound like its coming from in the bay? Report
July 21, 200917 yr Author comment_360453 definantly a bay sound. ive got tomorrow morning off, ill have a look to see if i can spot anything obvious and report bak. Report
July 22, 200917 yr Author comment_360507 just had a quick look. my steering box was dirty as. if i took it apart and cleaned all the crap out of it would it make it handle lighter? Report
July 22, 200917 yr comment_360706 Hey if you need another box I have one in a car I'm wrecking plus Curly has one is Lolla. The Lolla one was good, I never had issues with her :P Report
July 22, 200917 yr comment_360724 pretty sure a steering box needs to be 'full' of oil? or very close to full. Report
