August 2, 200917 yr comment_363098 Can I use this coil with my electronic ignition? The car is a KE11 and it has electronic ignition. It looks standard but may have been swapped at some stage. All I know is it uses the same rotor button as the Toyota Liteace (5k) Can I just swap the coils over or is there more to it? Excuse the toys in the photo. Report
August 2, 200917 yr comment_363153 Yes you can use it, but you need to find out if it is a GT40 or a GT40R, bit hard when the sticker is ripped off. If its a GT40R then ther only difference is you need to keep you ballast resistor. Report
August 3, 200917 yr comment_363195 If you run a GT40R coil on a electronic dizzy it will shit its self...Dizzy needs to run at full 12V on the 2 wires that go to the coil. If you under power it it will die in a few months. don't wanna kill a electronic dizzy. Get a GT40 if you want the GT series coil as they run at a full 12V. But I still think the stock denso coil packs a fair punch so try the wrecker for one. Cheers Cameron Report
August 3, 200917 yr comment_363200 You'd be better of with one of the black Bosch HEI coils. The orange ones are for points dizzies and have a lower output than the black ones. Report
