i adjusted the rear brakes, then i jumped in the car, started it and foot went straight to the floor?
so then i over adjusted them untill they didnt turn, still no brakes
wheel cylinders werent leaking
handbrake did work?
wtf i can't understand whats going on HELP
cheers
Evan
like i clamped the rear rubber hose and pedal was normal?
how did air get in the system?
stupid ke55
Edited by Evan G
stupid ke55
Yes indeed, stupid KE55. Best bet is to piss it off and buy an Aussie car.
Why don't you try bleeding the rear brakes, or indeed the whole system and see if that works?
lmao everything i seam to fix just turns out worst, i done a sump gasket 2 times and its still leaking :lolcry: scary part is I'm a 2nd year apprentice
yea thats my best bet,
Edited by Evan G
what have you been doing the last couple of years
if you didnt know no pedal = air in the system then you must be pretty retarded
wheel cylinder has probaly had it, pull off the rubber boot and see if its leaking
Alright take it easy on the kid.
One might wonder how the F you 'do' a sump gasket though.
so two years of on the job training and you still don't know that pedal to floor usually = air in system.... or no fluid.. did you put fluid in it?
Gotta agree with Roo, WTF have you been doing?
