August 15, 200917 yr comment_366132 ive got a ke30 with a 4 speed, I'm doing a ke70 5 speed conversion to my ke55 and I'm wondering if the ke30 pedal box will mount up to my 55. also will the 4 spd speedo cable fit the 5 speed and ke55 speedo? what tailshaft do i use to connect the ke70 5 speed to my ke55 diff? cheers Evan Edited August 15, 200917 yr by Evan G Report
August 19, 200917 yr comment_367205 :) Why do you need to change the pedal box when you already have a manual!? ...hand on, is the ke30 the parts donor for a KE55 manual conversion? Report
August 19, 200917 yr comment_367208 Yes, It all fits. only mods/ possible mods being; May have to swap to a KE70 gearbox crossmember to use the 5spd mount. And the shifter is further back on the KE70 box. you will have to cut a section of your tunnel out to allow the shifter to come thru. Just extent the original shifter hole Approx 3 inches (75mm/7.5cm) rearward. Once the gearbox is in, and the shifter is thru the floor. Grab yourself some sheet metal and cover the now unused section of the shifter hole. Attach it to the floor with either rivets, screws or some good ol Sikaflex. The Sikaflex is probably the easiest to do and is PLENTY strong enough to hold it there. I had a great time trying to pull the plate off the floor when i stripped the car. Good luck. EDIT: Just read Taz_Rx's post, if your KE55 is auto, then you will need to do some fab work to allow the gearbox mount to line up with the crossmember. The KE70 mount sits a fair whack forward of the 30/55 auto crossmember. I used a piece of thick steel plate welded to the top of the auto crossmember and then welded the gearbox mount on top of the plate. can't remember how far the mount was out tho. Edited August 19, 200917 yr by SLO-030 Report
August 19, 200917 yr Author comment_367259 I'm planing a manual conversion for my 55, i got a ke30 that a mite borrow the pedal box as long as they are interchangeable my question has been answered thanks Report
August 19, 200917 yr comment_367282 And the shifter is further back on the KE70 box. you will have to cut a section of your tunnel out to allow the shifter to come thru. Yes the manual shifter position is further back than a 30-55 manual, Although.... Assuming your 55 is an Auto I believe the 70 shifter should lineup well with the hole that is already there from the T-Bar shifter. Also, the existing speedo cable should fit you manual box (you may need to exchange the drive-gear from the auto into the 5speed) Report
