August 21, 200917 yr comment_367598 Please, does anyone have a exhaust-intake manifold gasket suit 4K engine. My head is ported and has extractors and ive had a couple gaskets made up which work for 2 weeks then begin to tick again ... grrr! The one that was made for the head has now fallen apart. So, wanted to buy - manifold gasket suit 4K with ported head & extractors.... cash! Report
August 21, 200917 yr comment_367603 Go to your local parts store and order an extractor gasket. ACL part no. DSF24 Permaseal part no. EM30 Report
August 21, 200917 yr comment_367609 thats your best bet, if you make your own make sure it is the right temp range, flame proof, whatever suits the job it is going to do. you might be able to cut down a proper gasket if you buy one new?? not sure if it will work, can anyone shed some light on this? Report
August 21, 200917 yr comment_367621 thats your best bet, if you make your own make sure it is the right temp range, flame proof, whatever suits the job it is going to do.you might be able to cut down a proper gasket if you buy one new?? not sure if it will work, can anyone shed some light on this? I have the same problem! Just go to your local exhaust shop, buy a regular gasket and cut it down. Report
August 21, 200917 yr Author comment_367673 Òriginal gasket too small in diameter. The heads porting doesnt leave much gap. Even extractor gaskets looks too small. What do you think? Report
August 22, 200917 yr comment_367889 $10 bought me a Duropro one- picture in here- http://www.rollaclub.com/board/?showtopic=27374 Report
August 26, 200917 yr comment_368845 I'm running the Permaseal, and my heads are portmatched to my manifold. Report
