September 4, 200917 yr comment_371237 have a ke20 have problems with erratic starting have good battery ,good coil chaecked all electric plugs starter moter.motor is a 5k with 5 speed manual all stock.motor is out of i believe toyota hiace.Once started runs fine.NEW ALTERNATER good points new eath leads,really frustrated. Report
September 4, 200917 yr comment_371286 more info mate Definitely- Is it only the first start int he morning, or only when its hot, or randomly.. Does it turn over and over and never fire, or coughs and coughs but never catches, or catches but runs badly & dies or... Report
September 5, 200917 yr Author comment_371460 tell me what u call erratic starting? more info mate think i got it sussed had a crook ignition relay Report
September 5, 200917 yr comment_371464 yea thanks for the extra info? tell me why u think its a ignition relay? Report
September 5, 200917 yr Author comment_371487 yea thanks for the extra info? tell me why u think its a ignition relay? ive tried everything else, the relay was a bit corroded,pulled it apart cleaned it up seems to have made a big improvement.The problem with starting is the engine labours to turn over and then it comes good and you get good strong cranking.Will put in a new relay and see if its better Report
September 6, 200917 yr comment_371745 if you want to do a goooooood job, make your own relay and put it close to the starter as possible (attach it to chassis rail) so you get no voltage drop what so ever Report
