Calam05 Posted September 4, 2009 Report Posted September 4, 2009 i have a ke55 coupe, it has stock rear speakers with the grey cover over the parcel tray with grills in it for the speakers. completely stock. I'm wondering is this something thats too good to chop up to fit sum 6.5's???? Quote
towe001 Posted September 5, 2009 Report Posted September 5, 2009 If its in good nick use it as a template on some 12mm MDF and do up a custom styled one Quote
Calam05 Posted September 5, 2009 Author Report Posted September 5, 2009 If its in good nick use it as a template on some 12mm MDF and do up a custom styled one yeh i had this thought today too. might give it a crack. Quote
RA28GT Posted September 5, 2009 Report Posted September 5, 2009 MDF will make for a MUCH better cleaner sound as long as its mounted well. Quote
JiP Posted September 5, 2009 Report Posted September 5, 2009 Before you rip yours out come see me. I have a overrated one in the garage that you may borrow to make the template. Quote
towe001 Posted September 5, 2009 Report Posted September 5, 2009 When you do it don't expect it to slide straight in you'll have to re-shape the board around the window, seat belt mounts (possibly use longer bolts) and the top of the seat So after you've cut the board, don't go and cover the thing, trial fit it firstly :P MDF will make for a MUCH better cleaner sound as long as its mounted well. You'll find two holes, on the inside sides of the speaker grills its where the plastic plug things are - they'll make ok bolt holes to hold the shelf down as well as the anchor points for the seat belts Quote
