Medicine_Man Posted June 17, 2005 Report Posted June 17, 2005 pimp the background out in white and insert a black light in your dash..
Jason Posted June 17, 2005 Report Posted June 17, 2005 And put some of the UV activated stuff on the needles :P
Jason Posted June 17, 2005 Report Posted June 17, 2005 OK ive got the step by step in photo shop. 1. Scan the image in.
Jason Posted June 17, 2005 Report Posted June 17, 2005 (edited) 2. Use your magic high light tool to outline all the text, numbers and markings you need Edited June 17, 2005 by Jason
Jason Posted June 17, 2005 Report Posted June 17, 2005 (edited) 3. Copy the selected parts and then past them onto a new layer. Edited June 17, 2005 by Jason
Jason Posted June 17, 2005 Report Posted June 17, 2005 4. Edit them until you are satisfied. I just inverted it then cleaned it up.
Jason Posted June 17, 2005 Report Posted June 17, 2005 (edited) 5. Clean the back ground layer up. First turn you dial layer off so you can see easier. You can add a image now if you want. Edited June 17, 2005 by Jason
Jason Posted June 17, 2005 Report Posted June 17, 2005 (edited) 6. Turn the dial or layer 1 if you haven't named it back on Done :D The reason why i didn't clean the entire back ground up was that most of it is not seen 1cm below the straight line. HIJACKED! :P Edited June 17, 2005 by Jason
demuire Posted June 17, 2005 Report Posted June 17, 2005 Nick: Your stickers are actually layered aren't they (as opposed to printed)?
Jason Posted June 17, 2005 Report Posted June 17, 2005 (edited) Hmm interesting, because the red line of the gze start at about 8000rpm... As Fook said before are they layered? Because the shinny gloss looks real hot :P Ok, test fits with paper prints. Edited June 17, 2005 by Jason
demuire Posted June 17, 2005 Report Posted June 17, 2005 Hey wow, that's pretty cool. Maybe if you printed them on photo paper... Hey then you can like put a photo of your face in the background :P
demuire Posted June 17, 2005 Report Posted June 17, 2005 (edited) Or a Teletubby. Better yet, you can have one that goes: Speedo: Stop Slow Cruisin Fast Very fast OMG fast! And then for your tacho you could have: Engine off Idle Power start here Power end here Red line BOOM! Or something silly like that. Or, you could take away ALL the lines and just have 0, 40, 50, 60, 70, 80, 90, 100, 110. And that's it. :D Or you could have: Stopped School Zone Residential area Most roads Rural stuff Big roads Slow highway Normal highway Fast highway :P I'm silly. Edited June 17, 2005 by demuire
