My clubman 7 has a KE55? rear axle. The handbrake cable exits from the front (ahead of the axle) of the backing plate as standard currently.
The cable and mechanism would work much better (smoother) if the backing plates were reversed (ie. swapping left to right) to allow the cable to exit behind the axle. What would the implications of this swap be? Would general braking OR handbrake function be affected in any way?
Regards
If you swap the backing plates then the handbrake cable entry points are going to point towards the back of the car!!
Flipping them upside down would point them back to the front of the car, but then you'd need to modify the brake lines and I don't think the backing plate to axle bolts are in a square so you'd have to re-drill the backing plates to suit.
All in all, put it in the "Too hard basket" cause you're not going to get any real gain from it. :)
