October 18, 200917 yr comment_383100 So recently bought and had installed a recon 5k motor, had all my old stuff of the 4k put on there. First question is while wearing the motor in like a grandpa ofcourse I've been noticing when I slighty put my foot down while not under load and in low revs I get a loud almost tapping sound? Second question is it worth putting a 5k started motor in or is the 4k one plenty enough? Think my current one is struggling so wanting to replace shortly. Thank you in advance Scott Report
October 18, 200917 yr comment_383123 regarding the starter motor question, is it a bog stock 5k? or mild engine? check your earth wires and upgrade the wire that goes between the battery and starter motor to a thicker one Report
October 18, 200917 yr comment_383124 Check your leads etc to the battery. I'm running high compression 5K and the stock ones do the trick fine. Mind you the 5K reduction starters are highly recommended but don't come cheap. Edited October 18, 200917 yr by philbey Report
October 19, 200917 yr Author comment_383462 Sorry got stock 5k with 32/36 weber apart from that and extractors completely standard. I'm thinking the sound I'm getting is pinging how do I check? Thinking I will just replace the starter motor and while there check the wiring Report
October 19, 200917 yr comment_383549 Sorry got stock 5k with 32/36 weber apart from that and extractors completely standard. I'm thinking the sound I'm getting is pinging how do I check? Thinking I will just replace the starter motor and while there check the wiring The "tapping" sound is pinging/detonation... It means the timing of the distributor is too far advanced and it is sparking BEFORE it needs to, making you lose a LOT of torque. If you don't have a timing light, just keep retarding it (less advance) and drive it up hills to test if it is still pinging. Once it stops sounding like you have marbles in your motor you should be pretty right; but it does help to get it properly timed. Edited October 19, 200917 yr by seabiscuit Report
October 19, 200917 yr comment_383623 What type of fuel you running? If using ULP then try some PULP and see if it stops pinging. Report
October 20, 200917 yr Author comment_383888 sweet will do thanks guys, yeah i did notice and thought it was pinging once i put in normal ULP instead or the usual PULP. Report
