October 29, 200917 yr comment_386705 Removing the snorkel from my AE102R...was a bit tricky but i have it off now. Now i noticed that through that hole where most people put their pod is a black box. What is it? It's just inside the front wheel guard. Report
October 30, 200917 yr comment_386733 It's an Air Resonator, keeps a whole lot of air available so when you decide to put your foot down it has enough air to match the fuel injecting into the engine... Report
October 30, 200917 yr comment_386742 Its a resonator but its designed to reduce induction noise. I doubt it has any effect as a surge tank. Report
October 30, 200917 yr Author comment_386747 It looks as though i have to remove the whole splashguard to get to it.....Damn! Fun times :2thumbs: Oh, i found one of Hiro's posts on Toyomods - think i'll just follow that for now. Edited October 30, 200917 yr by Satyr Report
October 30, 200917 yr comment_386771 It looks as though i have to remove the whole splashguard to get to it.....Damn! Fun times ;) Oh, i found one of Hiro's posts on Toyomods - think i'll just follow that for now. That's the whatsit :2thumbs: It's not really that hard, take the battery and the fuse-boxes out will make a bit more room, and turning the wheels all the way to the left gives you a bit more room around the wheel-well as well. Should only be two or three bolts that hold the resonator in, but might be handy to have a second person around in case you need a spanner on each end - kinda hard to do something in the engine bay at the same time as your head is stuck under the guard. Report
