Just Finished 4ac To 4age Conversion On My Ae86
hey peoples i was told that i can see use my standard accelerator cable from my 4ac on my 4age .
am i doin it right?
or do i need 2 replace it?
also if i need 2 change it , what car should i take it off for a direct fit
any help would be good as always
thanks pplz
the ke70 one fits quite nice
so i take it thats what everybody does? and theres no point of trying 2 make the ae86 cable fit
definitely no point
thanks sam ur a champion , i should have the car up and running in a few days , ill take pics 4 ya
sounds good, I would like to see it
oh by the way changing the cable is a bit of a shit job
hmm I'm not so sure sam.
i used a ke70 cable on my 4age conversion (into ke70)
now i found the cable to miles to long. it was binding up quite badly which made the accelerator pedal quite long.
but.,.you say you converted from 4ac, so i assume you had a 4ac cable before.
4ac's having the carburettor on the other side of the engine will mean that the cable will be shorter. but I'm not sure if it will be too short. the reason i say that is i hear alot of ae86 boys (4ac) having dramas with the standard ae86 cable not being long enough (4ac).
on my car i ended up shortening the ke70 (4kc) cable. all i did was cut out a piece of the plastic casing and sorta made a "splint" to hold the rest of the cable straight.
yeah I guess I should of asked which 4age he put in
