ok once again i have a problem
its probably simple but ive tryed to get it to work it wont
acouple of days back i fitted twin delorto dhla 40s the car has started and ran a handful of times but now it doesnt want to start right it wants to go wer wer wer but not enough to turn it over =S its also hard to start because it takes abit with the carbies on it sometimes it come close but when i go to try it again it has no poke =S
so if someone can help that would be great
thanks mitch
try another battery
also check timing it could be out which will make it hard to start
what fuel pump are you using... may not be getting enough fuel to the twins..
there is heaps of fuel standard pump though upgrading to electric soon
only other thing i tryed to start it for about a minute and it started smoking from around the carbies =S
its started and ran fine about ten times or so
I'm gonna put the leads on it tomorow and see if that helps
The pressure from the standard pump may be too much for the needle and seats in the carbs. It isn't a jetting thing. The fuel bowl keeps filling then overflows because the fuel pressure is too high for the needle to seat and stop the flow of fuel.
Does it stink of fuel?
But then it could be other things.
Does it turn over at a constant speed though just doesn't fire? Or is it actually just not cranking over at a constant/steady speed?
I'd be leaning away from too much fuel pressure, though that's not to say it isn't the case. I have had twin 40s on my car for over 6 months now with the standard mechanical fuel pump and havn't had any problems.
If it had started and ran before, I'd be putting money on a dud starter motor/battery or along those lines.
Well before you start paying out for adjustable regulators, you should work out whether that is your problem. Not that a regulator would hurt.
Presumably you have run the battery down trying to start it. If you have been pumping the throttle it will be flooded.
Fully charge the battery, and work through logically. If all you have done is bolted on a manifold with carbies, look back at what you have done and check your work.
Once the battery is charged, try again whilst holding the throttle down, but do not pump it. You are trying to clear out fuel mixture.
If it starts, it will likely run like a pig if it is jetted for a 2 litre.
ill take the battery out tomorow and do that
ive been over the carbys manifold all my lines and emitions about 3 times because i have had acouple of air leaks witch are all fixed now
i have had it running its not to bad it just idles abit high
id say i have flooded it the last time i pumped the throttle about 3 times as i was getting pretty short with it
Battery is first stop.
Then pull your plugs out and rub the electrodes with a bit of emery paper. Chances are you have fouled them with all this over fuelling etc.
Then crank it and don't give it more than one stab on the throttle.
I'd just go get the fuel pressure reg - my pump was putting out more than 5psi. There's so many different pumps out there blinded might just have got lucky with his.
50 bucks for a holley red.
Clean plugs as mentioned. give the carb 3-4 pumps then hold them flat open; that's how I start my dellortos every morning, no problem.
