November 29, 200916 yr comment_394346 Hey Guys and Girls, Chasing someone that could make me a tyre placard sticker to my specs. Is basically a stock one modified to suit my needs. Bellow is one i made in excel and dimensioned in paint so excuse the crudeness. Anyone that can help, please PM me. CHEERS Ryan Report
November 30, 200916 yr comment_394529 what are you trying to achieve from this? I could best suggest you try to buy a new tyre placard from a later model corolla that has specs that you desire and stick it in place of factory one. If not possible, why not take a digital photo of the current one, photoshop the details in that you wantm then take it to a signwriter who should be able to print a sticker for you. good luck, would like to see how it goes as i've thought of doing something similiar. -dave Report
November 30, 200916 yr Author comment_394551 Hi Dave, I'm doing this because as it is there are two spare spots on my stock placard. As SA regs go i can only increase my rolling diameter by 15mm. So i figured, put in the details i want so if a cop looks at the card. everthing will appear within limits. I know of a few guys doing this on late model commodores to be able to run 20's and stuff. CHEERS Ryan Report
November 30, 200916 yr comment_394560 how big do you want to go??? I had 205/40/17's on my ke38. They fit beautifully, on 17 x 7 rims. I don't know how much i went bigger in rolling diameter though... good luck. :D I was going to use a late model corolla tyre sticker, cause no cop is going to check to see whether the model code lines up with the tyre placard. I was going to use one that said i ran 15 inch wheels stock. but now i'm back to 13" anyway.... Report
November 30, 200916 yr Author comment_394584 how big do you want to go??? I had 205/40/17's on my ke38. They fit beautifully, on 17 x 7 rims. I don't know how much i went bigger in rolling diameter though... good luck. :D I was going to use a late model corolla tyre sticker, cause no cop is going to check to see whether the model code lines up with the tyre placard. I was going to use one that said i ran 15 inch wheels stock. but now i'm back to 13" anyway.... I want something that'll give me some breathing room if i choose to run some mid profile 15's I might be able to get away with it now but just in case :| Will scope the wreckers tomorrow arvo or the weekend to see what i can find. Cheers. Report
December 1, 200916 yr comment_394725 Anyone heard the word fraud. If you are in a serious accident and they find an illegally modified sticker then you will be in the shit, both with insurance and legally. That said - get some sticker sheets that can be printed on. Just like the print on labels but bigger. Print your image and get some "water proofing" spray from an art shop (I use Crystal Clear approx $12 can) to coat your sticker. Once dry cut it out and stick it on. Report
