i went down the local pick a part and saw 4 coronas with int wipers and i couldnt find the control box?
wheres the control box on ke**?
cheers fellas
Evan
i was a bit confused when i saw the corona loom,
like 7 wires on the wiper motor on the corona and 5 on the corolla?
on the corona the wiper loom goes on 2 separate relays on the bottom kick panel before the control box?
sounds like a nightmare if the whole dash loom needs modifying
I'm pretty sure you can get an aftermarket switch that has a built in intermittent, my ke35 doesn't have the intermittent so i was just going to put a seperate switch somewhere, should be a kit available from jaycar or dicksmith or something. Might look into that and actually give you some helpful advice :dance:
Edited by jono1986
  • 5 months later...
