January 27, 201016 yr comment_408855 first off: this is a re-post, had it in the wrong forum... anyway... a few fitment questions, are these a direct fit into a ke70? all ae86 parts, if not a direct fit, is it possible to fit them? - adjustable lca's - rca's - steering knuckles - outer tie rod ends (power sterring) - tension control tie - lowered springs (front & rear) - traction brackets - rear 4-link - front swaybar why i ask when everywhere says "most front suspension parts are a direct swap" is because that is a tad vague, and all of those are adjustable / non-standard items... i found the parts this ebay store when casually looking for some cheap cambertops: http://stores.ebay.com/Techno-Toy-Tuning they seem ok, and they make mention of aussie customers and i was wondering if anyone had used them before?i mean, ebay and all... Edited January 27, 201016 yr by lanceishere Report
January 27, 201016 yr Author comment_408863 some 86 struts are probably in the works too, they a straight swap? Report
January 27, 201016 yr comment_408864 some 86 struts are probably in the works too, they a straight swap? You can use any ae86 front suspension parts even swaybars. Just use ke70 strut tops. The rear is the same use whatever you want. Its all the same fitment to the car. You need ae86 struts to use ae86 roll centre adjusters and steering arms. Its also cheaper if you do not go through ebay. http://www.technotoytuning.com/index2.php Report
January 27, 201016 yr Author comment_408865 You can use any ae86 front suspension parts even swaybars. Just use ke70 strut tops. The rear is the same use whatever you want. Its all the same fitment to the car. You need ae86 struts to use ae86 roll centre adjusters and steering arms. Its also cheaper if you do not go through ebay. http://www.technotoytuning.com/index2.php thanks man, couldn't find any mention of a website... should of googled it :D Report
January 31, 201016 yr comment_409596 thanks man, couldn't find any mention of a website... should of googled it :) Ive bought a pair of camber tops for my ke55 witch didn't fit, they refunded the price and postage straight away! best U.S customer service Ive used to this day! Report
January 31, 201016 yr Author comment_409852 Ive bought a pair of camber tops for my ke55 witch didn't fit, they refunded the price and postage straight away! best U.S customer service Ive used to this day! yeah, i was worried about the fitment on a set of shifter bushings i want to order... the ke70 k50 and ae86 t50 ones are identical... :) Report
