Cream Dream Posted February 15, 2010 Report Share Posted February 15, 2010 (edited) hey guys probably a bit of a stupid question but does a t18 diff assembly bolt straight in to a ke70 or do i need the t18 tail shaft as well or do i have to customize stuff???? any help would be appreciated cheers :) Regards Mike Edited February 15, 2010 by Cream Dream Quote Link to comment Share on other sites More sharing options...
LukeAE71 Posted February 15, 2010 Report Share Posted February 15, 2010 Need a T18 rear half shaft. Other than that it bolts in quite well Quote Link to comment Share on other sites More sharing options...
Cream Dream Posted February 15, 2010 Author Report Share Posted February 15, 2010 Need a T18 rear half shaft. Other than that it bolts in quite well sweet i might have to go grab this one then do i need all the arms and shiz from the t18 as well or do the ke ones bolt on to the t18 diff? cheers Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted February 16, 2010 Report Share Posted February 16, 2010 link bars are all the same, shocks bolt into the same place, brake lines have all the same connections, it even has the same spring platforms. It's just the tail shaft that is different where it bolts onto the diff flange. Quote Link to comment Share on other sites More sharing options...
beerhead Posted February 18, 2010 Report Share Posted February 18, 2010 BTW, If your keeping the K motor, I'm fairly sure the rear piece of the T18 shaft will not bolt to a KE70 front half. Totally different diameters. You'll need a full tail shaft and have to swap the front yoke off the KE70 to the T18 shaft. Quote Link to comment Share on other sites More sharing options...
