Ke70 Lowering
hey guys i have 200mm rear springs for my ke70 and need to know what shocks i should use went to they suspension shop and they had no idea can anyone help
yes i have looked but its just confusing me lol
thanks guys model numbers would help cheers
Edited by KE70PWR
Do you want to know what front springs will match your rear springs? You ask your question in a very round about way.
When you say your rear springs are 200mm - is this the height of them measured out of the car? Are they stock springs that have been cut, are they falcon springs that have been cut, are they lowered king springs? basically what i am saying is that you haven't given any one enough information to even begin helping you.
Don't cut your standard spring with an angle grinder. your call will handle like soggy poo.
Best solution is to buy lowered king springs front and rear
If they are still not low enough take them to a spring works and get them reset.
200mm rear springs are as low as I would go if its a daily/street car.
As everyone else has said though you haven't really provided any information.
If they are stock rear springs, only cut. It's going to be too low
If you are wanting to know what height front springs to use, the general rule is the same as the rear, a little lower preferably.
When/if I build another KE70 for the street I will be going 210mm 6kg front springs, and 235mm 4.5kg rear springs
i want to know what shocks to put into the back i have 200mm free height springs (thats out of your car for those who don't know)
just what shocks thats all i want to know
then thats what you should have asked in your original post.. not springs like you did!!!
trd.. koni.. kyb... monroe..
how much money are you wanting to spend??
i don't want to spend alot of money
i need to get them before the weekend
And some cheap monroe shocks or boge from ajps.. or kyb
You arent going to get anything cheaper. and they proabably wont be short stroke.
KYB VN wagoooooon rears.
343113. Short stroke, and can easily be sourced from just about any autoparts store.
thanks guys put sierra front shocks in it the vn ones were a little to long still
cheers rides so much better now
