was driving my ke (4k) today and did some fishys down a dirt road when i got to the end of the road and stoped it didnt wont to idle and just about stald now it whont idle under 1100rpm i had to turn the idle screw up so it whont die and when i come to a stop quickly it just dies or idles ruff can somone help? my gess is its the carby flot
Edited by vsschris
i have the exact same problem at the moment, can't drive it without the choke, i thought it was maybe the timing, so i got the timing done and it runs a bit better but i still have the same problem, the guy who done my timing told me to put a carby kit through the carby because that is most likely the problem, i got the carby kit yesterday and am yet to have put it through the carby, but ill let you know if it helps me at all, might help you
