April 21, 201016 yr Author comment_431487 4 either side. Done them.. There are no actual bolts left to take off except the one that goes to the tail shaft... Hmmm weird. Report
April 21, 201016 yr comment_431531 Tried Brake Drum, Tried wheel and a sledge hammer.. Hmmm isn't getting very far, Hopefully Trev will reply soon. Report
April 23, 201016 yr comment_432077 And they're out. Finally. Ended up putting the brake drum on backwards (tight) and smashing it with a big sledgehammer :laff:. Done the trick so I'm happy. Thanks for the replies anyways guys and girls if their were any :D. Report
April 26, 201016 yr comment_432708 I'm going to revive this thread even though its not that old. Putting the diff Back together. Info: When i pulled the diff center out 4 (2 either side) i'm assuming spacers or something fell out. On either side one is thin and one is bigger. Question: Which way do they go.. Thin closest to center or bigger closer to center. and is it same on the other side ie thin closest to center. Cheers. Report
April 27, 201016 yr comment_432836 The rings you speak of are shims to reduce play in the centre, and its pretty important to put them back in where they came from otherwise your diff will be setup incorrectly. If you didn't take notice of which was which I suppose you just going to have to install them each way and see which has less play in the diff. Report
April 27, 201016 yr comment_432916 I Figured it out Ended up having to go get new shim's from the wreckers coz i snapped one trying to get the dif back in.. Was weird, The ones i got today were completely different to mine yet same car :wink:.. Now i just need to fit to car and add oil etc. Report
April 27, 201016 yr comment_433094 :) The reason they are different is because over time the diffs have worn differently and been re-shimmed to suit. I don't really think what you have done/are doing is a good idea. I would be tripple checking the diff play befor putting the backing plate back on. If the diff has too much play its just wear itself out completely in under 6 months. Report
April 28, 201016 yr comment_433220 Erm there's no real play anywhere that I've noticed. Everything seems to fit nicely. Where will this so called play be if there is any ? Report
April 28, 201016 yr comment_433235 in and out on the axel dude and it has to have a little or it will tear itself to pieces Report
April 28, 201016 yr comment_433257 Well Yeah there seem to be a little movement if you pull and push wheel but nothing bad. Brother was playing with that today Report
April 28, 201016 yr comment_433342 What, NO you shouldn't have any play in your axles. If you do it means the bearings aren't pressed on as they should be or the retainer bolts are loose. The play I'm talking about is between the crown wheel and pinion, aka diff slop. Report
April 28, 201016 yr comment_433349 What, NO you shouldn't have any play in your axles. If you do it means the bearings aren't pressed on as they should be or the retainer bolts are loose. Or the wheel bearings are stuffed. Report
April 28, 201016 yr comment_433353 I fixed the push pull.. And the rims are somewhat fk'd.. As for the movement in the pinion etc gears, There isn't any i know of :).. I know nothing about the diff.. It works the wheels turn etc. Report
April 29, 201016 yr comment_433355 Well if you can't feel any play then now you're running the risk of having the diff shimmed up too tight. This is why you need to remember which one came from which side. Stock up on Bananas now!!! :) Report
