Boosted Holden Ute
Model: 1993 VP ute
Colour: Canterbury Blue
Bodykit: VP GTS front bar, VT clubby skirts
Engine Type: 3.8L V6
Engine Mods: T3/T4 Turbo, 42lb injectors, 600x300FMIC, Haltech Ecu, 600hp intank fuel pump
Power: 217rwkw
Exhaust: 3" turbo back
Gearbox: T5 5speed manual, HD oragnic clutch
Diff: 3.45:1 LSD
Brakes: front 322mm Slotted rotors with twin piston calipers, rear stock slotted
Suspension: superlows allround, 31mm front sway bar, 22mm rear adjustable sway bar, camber/caster kit
Wheels/Tyres: 17x7.5 PCW Sensei
Interior: Stock, power windows, boost, water, oil gauges
Other Mods:
Stereo: Kenwood MP333 HU, Blaupunk amp, VDO 6" splits, 800w 10" pioneer sub
Build Period: ongoing
Cost: cheaper then a bought one
Contacts:
Future Mods: repositioned and better turbo more boost, stateman interior, paint
Youtube Video ->
Edited by LowVp
Good looking setup, Do you ever get ignition breakdown from the exhaust being that close to the coils.
Have not seen this around Ipswich as yet.
yeah on occasion so regular trips to the wreckers to buy coils, haven't taken this into town in a while. last victims were a vy clubby and a ve clubby and haven't been back in there since
Some ACL heat shield might give you a bit more time between coil changes :wink:
I think I have seen the camry around.
V6 will be coming out and a LS1 and T56 going in its place, so i'm not really going to change much with it
Just buy a roll of cheapo exhaust wrap and wrap the exhaust with it (not good for longevity of the manifold/s but will work until you swap it out)
ACL heatshield is cheap as chips too.
Tidy setup though.
Hey Dru,
I see you've got the driveline up for sale on proUTES.....LS1-T56 soon?
Edited by SLO-030
yeah time to go bigger and faster
bought some goodies and it stops on a dime and almost near turns on one
old front braking setup
Edited by LowVp
Nice, what brand rotors are they, I thought alcon at first but they have more of a crescent moon.
RDA rotors, PBR calipers
ok. well atleast you are going to be able to get a decent alignment with the kmac camber tops.
yeah got brendan at goodyear opposite coles to dial in -2.0 degrees of camber and +4.0 of caster, handles like a go kart
