May 7, 201016 yr Author comment_435641 My carbs are the horizontal mounting type, there are very similar ones with a 45 degree float bowl. Report
May 7, 201016 yr comment_435643 Yeah so I am saying don't mount them so the intake is 100% horizontal. Report
May 7, 201016 yr comment_435649 Yeah, Maybe a bit more, The pic you posted looks like the rear is lifted slightly. Report
May 7, 201016 yr comment_435654 This is a hell of a head clean up! I look forward to seeing the results :jamie: Report
May 26, 201016 yr Author comment_440260 Ok lesson learned. The carbon on tha valve seats and valves themselves were actually sealing the engine, however they did it badly. Then when I cleaned it off even lapping was not enough to get a proper seal. I put it all back together again and started the engine. Rough idle and black smoke pouring out the back on throttle and just really smoggy at idle. Checked the timing and all and that was fine. The carby wouldn't run rich would it????? I didn't change anything apart from a good clean with carby cleaner in and around. So I rang TW Engineering and got a quote at $8 per valve and something that I can't remember per valve seat at a total cost of about $130ish. Would have been far less hassle if I gave it to them in the first place..... But we learn from our mistakes and best of all I can now rip apart the head and put it all back together again no hassle! Report
May 27, 201016 yr Author comment_440494 Thumbs up to TW Engineering! $100 to get the valves re-seated and head re-faced. Report
May 28, 201016 yr comment_440677 Yeh wayne is a champ, especially if you get talking hot rods with him. Report
