May 23, 201016 yr comment_439527 Hey guys.. just built a 4agte.. I'm after new injectors but are unaware of which will suit and be bigger enough.. i'm after 550-650cc was told mitshibishi magna blue 1's.. are good ? any help please Report
May 23, 201016 yr comment_439614 magna blue injectors off the top of my head are only 24lb, about half the flow of what you need. here is a link to a mob that rejets and matches injectors. i picked up a set of 42lb injectors for 300 bucks landed here from the states. just check the design style and flow rate http://www.deatschwerks.com/catalog/produc...products_id=146 Report
May 24, 201016 yr comment_439658 13bt injectors are pretty commonly used for upgrades in other cars. They're 550cc. Also readily available and cheap as there's plenty of people putting bigger ones in the 13bt's. ;) Report
June 19, 201016 yr Author comment_445762 4AGZE Injectors.. what CC are they.. ? Will they be ok ? As i'm buildin a pretty full house motor... Report
June 19, 201016 yr comment_445774 http://www.deatschwerks.com/catalog/fuel_calculators.php use that and bear in mind you only want to use 85% of the injector for max hp Report
June 19, 201016 yr comment_445798 How big a turbo are you running and whats your estimated peak HP? Report
