RND.IGO Posted May 23, 2010 Report Posted May 23, 2010 Hey guys.. just built a 4agte.. I'm after new injectors but are unaware of which will suit and be bigger enough.. i'm after 550-650cc was told mitshibishi magna blue 1's.. are good ? any help please Quote
LowVp Posted May 23, 2010 Report Posted May 23, 2010 magna blue injectors off the top of my head are only 24lb, about half the flow of what you need. here is a link to a mob that rejets and matches injectors. i picked up a set of 42lb injectors for 300 bucks landed here from the states. just check the design style and flow rate http://www.deatschwerks.com/catalog/produc...products_id=146 Quote
Taz_Rx Posted May 24, 2010 Report Posted May 24, 2010 13bt injectors are pretty commonly used for upgrades in other cars. They're 550cc. Also readily available and cheap as there's plenty of people putting bigger ones in the 13bt's. ;) Quote
RND.IGO Posted June 19, 2010 Author Report Posted June 19, 2010 4AGZE Injectors.. what CC are they.. ? Will they be ok ? As i'm buildin a pretty full house motor... Quote
LowVp Posted June 19, 2010 Report Posted June 19, 2010 http://www.deatschwerks.com/catalog/fuel_calculators.php use that and bear in mind you only want to use 85% of the injector for max hp Quote
beerhead Posted June 19, 2010 Report Posted June 19, 2010 How big a turbo are you running and whats your estimated peak HP? Quote
RND.IGO Posted June 24, 2010 Author Report Posted June 24, 2010 T4bb T3 rear housin.. at least 300rwhp Quote
