June 23, 201016 yr comment_446971 soOO i had an altercation with a random curb... :yes: things got outta hand.. and he pulled a sneaky swift sucker punch on my right front wheel whilst i was picking up my dropped fone from the floor.. anyhows i really got knocked the feck out.. :D :P :( got the wobbles.. but no external injuries... but next morning.. i seemed to have internal bruising..?? blah blah... hehe anyways guys.. after hitting and climbing the curb, next day: *on braking and pulling up for a red light she stalls.. *hard start up *rough idle *doesn't hold idle..stalls apparently these are common symptoms after a hard knock...?? so i've read quickly with a google search.. WHAT HAS HAPPENNED? also visual inspection on front end suspension shows nothing bent.. but car feels like it's tripping over it's own foot when turning... steering wheel 45degrees to the left to keep a straight line... feels like wheel wants to fall off but everything is per normal and tight.. ok getting to my question... whatcomponents get's adjusted during a wheel alignment? please share ur brains... thanks dudes! :D Report
June 23, 201016 yr comment_446973 Just some things that i can think of, something's happened to your float in your carby to mess that up, with the front end the steering rod thingy would of jump a couple of teeth in the steering box thingo. Also jack the car up and see if the wheel wobbles, could of bent it so when you turn its on a bit of an angle which might cause this 'tripping over it's own foot'. And also i don't know how other people might feel but it might be easier if you spoke in a more technical fashion when it comes to mechanical problems. Just my two cents.... Report
June 23, 201016 yr comment_446981 you've bent or buckled a suspension component, possibly a rim, a strut, a radius rod, a control arm bush, a steering arm, or even the chassis. you've probably got an issue with the float in the carburettor as well. Robert. Report
June 23, 201016 yr comment_446985 I thought you did a great job explaining the symptoms... my two cents worth. :yes: I agree with Robert. Our Celica was having similar issues, visually all looked ok but had several of those components bent. Got them replaced and a wheel alignment and she's as good as new :D Report
June 23, 201016 yr comment_446999 for the suspension side of thinkgs just take it to pedders and get them to check it etcetc. makes it easy and only costs like $14 then you'll know whats wrong. Report
June 24, 201016 yr comment_447000 Anywhere but Pedders I would suggest. They will tell you everything needs replacing, standard opperating procedure for most pedders stores. Your local tire place should be able to inspect and repair, Ian Diffen fixed mine. Report
June 24, 201016 yr comment_447006 hmm the guy i use is very respectale.. spose ya gotta find good people. Report
June 24, 201016 yr Author comment_447047 I thought you did a great job explaining the symptoms... my two cents worth. :D I agree with Robert. Our Celica was having similar issues, visually all looked ok but had several of those components bent. Got them replaced and a wheel alignment and she's as good as new :D :yes: :P Report
June 24, 201016 yr comment_447049 Check your lower control arm, strut, wheel bearing adjustment, check where the lower control arm mounts into the crossmember, all these thing may have been bent, or put out of shape/adjustment when your car decided to dive at the gutter, i would suggest replacing all the above things then get a wheel alignment, and get them to check it out and see how bad it is, cheers Justin Report
June 24, 201016 yr Author comment_447050 ok thanks guys.. now with the float.. can i attend do this myself? i have no idea.. but that doesn't mean i can't do it.. i'm good... lol just need to know what... yeah i don't like pedders.. sorry to say... but that's not to say there aren't good ones out there... but yeah why does a hard knock stuff up the engine's smooth running? Report
June 24, 201016 yr Author comment_447052 Check your lower control arm, strut, wheel bearing adjustment, check where the lower control arm mounts into the crossmember, all these thing may have been bent, or put out of shape/adjustment when your car decided to dive at the gutter, i would suggest replacing all the above things then get a wheel alignment, and get them to check it out and see how bad it is, cheers Justin :yes: fingers crossed only thing i can see is a split in the ball joint rubber... Report
June 24, 201016 yr comment_447131 tap tap taparoo the carby. hopefully this will unjam anything Report
