stupid instruction manual doesnt show shit!
anyways, everything is done except thers 2 ouputs on the oil pressure sender. one is W and the other is G
witch wire do i attach to the gauge?
my guess is G is ground? and other is ouput?
cheeersss
cheeersss
G goes to the gauge, The unit it earthed with what it is screwed too, Pretty stupid setup they have now.
cheers trev, so whats W then? Wank factor?
Maybe G = Gauge, W = Warning light. Check the resistance between the two wires and earth with the engine off and then when it's running; the W one might go straight to earth e.g. for the warning light and the G one will be variable resistance..........MAYBE
Edited by jono1986
nah the warning light is on when theres less than 10psi of oil pressure or when i short it to ground and shows 0
Switched feed like a light but if it does not work try hooking the earth to the W terminal, I installed some MARS performance gauges into a customers car and I only had to hook up to the G.
ill put it to signal wire to W and swap em over when I'm running in my cam, in the meantime i got the stock sender on the T peice to make sure i got oil pressure
