Cyo18r Posted July 1, 2010 Report Share Posted July 1, 2010 i have a ke70 and its low i mean no bump stops and i wanted to no if anyone nos what shocks i can get out of another car so i wanna change the front ones and back ones to a better shorter shock...... Quote Link to comment Share on other sites More sharing options...
RainWarriorDregs Posted July 1, 2010 Report Share Posted July 1, 2010 maybe Peddars and ask them for short stroke shocks for your KE70 or ones that are compatible. Do it right the first time you won't have to do it again. Quote Link to comment Share on other sites More sharing options...
bLinded_ Posted July 1, 2010 Report Share Posted July 1, 2010 KYB part number 343113 for the rear. Short stroke shocks to suit VN-VR Wagon I believe. Though if you have no bump stops left, that is probably to low to suit even the above mentioned shocks. I think another option is Sierra shocks for the rear. They would suit stupidly low cars... Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted July 1, 2010 Report Share Posted July 1, 2010 How low do those VN-VR ones suit. I'm 2 coils approx 50mm lower than standard. And I've heard fronts are impossible to find for standard E7 struts? Although I'm hoping to upgrade to xt130's very soon. Quote Link to comment Share on other sites More sharing options...
SLW42 Posted July 1, 2010 Report Share Posted July 1, 2010 I'd say go and find your self some sierra short stroke shocks for the rear of your car man, my car has had the coils cut 3 off a standard spring and it sits bullshit low and i will be trying to find some of them once i get some more cash, i have a full s13 front suspension setup with adjustable coilovers in it so the fronts aren't a drama for me, but call suspension shops and see how you go mate Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted July 1, 2010 Report Share Posted July 1, 2010 I'd say go and find your self some sierra short stroke shocks for the rear of your car man, my car has had the coils cut 3 off a standard spring and it sits bullshit low and i will be trying to find some of them once i get some more cash, i have a full s13 front suspension setup with adjustable coilovers in it so the fronts aren't a drama for me, but call suspension shops and see how you go mate Sierra are the worst shock option ever for corollas. Buy short stroke ae86 shocks or failing that the commodoore ones as above. If your too low for them raise it. Either that or spend some more money and get something made in a spring thats perfect for what you want, then buy good adjustable shocks for them too. Upgrade front struts to 2 inch and you have a lot more choice. Quote Link to comment Share on other sites More sharing options...
Cyo18r Posted July 1, 2010 Author Report Share Posted July 1, 2010 ok that kinda helps i asked a place and they said i should use a mazda 626 shock but oder them in as a short shock in the gt sports gas so i am trying to find out if anyone on here had any better iders..... Quote Link to comment Share on other sites More sharing options...
bLinded_ Posted July 1, 2010 Report Share Posted July 1, 2010 You won't find anything for the front. Reason being KE70 struts are a 45mm OD and all decent shocks will be to suit a 51mm OD strut tube. There is a reason why 99.9% of people upgrade their front setup for more than just the brakes. Also (Could be wrong on this) if you car is as 'low' as I am picturing, even a short stroke shock in the front will not be overly great as there will be f@$k all compression stroke. You would need to section the front struts by 20-30 atleast to try and make up some more travel. Which then means you'll want some RCA's to level your LCA's...etc etc. Quote Link to comment Share on other sites More sharing options...
mighty_4k Posted July 3, 2010 Report Share Posted July 3, 2010 Don't mean to hijack your thread Cyo18r but what are the options and what do I need for upgrading the front? I have superlow springs all round. Got kyb aftermarket shocks in the rear and its sweet but the front is still uncaptive so Ive got to find a solution before warrant of fitness time. Quote Link to comment Share on other sites More sharing options...
majordad Posted July 3, 2010 Report Share Posted July 3, 2010 RX7 Fronts could do the trick, Konis did the trick on Ke11 lowered 2" + Majordad Quote Link to comment Share on other sites More sharing options...
