Ke55 Bearing
Hey all
I'm after the part numbers for bearings and seals etc to rebuild my diff.
i don't have a spare diff to pull down to find the numbers either.
cheers, Luc
well i've found part numbers for brands such as Timken and stuff but there a 3 different part numbers for the same
car same year etc.
i don't know what to go with.
car same year etc.
Timken works. :P
nah thats what i'm saying every brand has 3 different part numbers for the same thing, so i have no idea which part number in any of the brands would work
ok so upon digging it seems that the numbers from that website are to suit t series or something else.
none of the numbers are correct.
back to searching. once the numbers are found they will be posted here for future reference.
perhaps but there is no way of telling.. although the description is the same for every bearing... 'rear axle bearing'
http://cpwstore.carpartswholesale.com/cata...sal:0)&sv=0
there's the link.
None of those are diff bearings! They're all front hub (inner and outer) bearings or rear axle bearings.
As you would know they diff bearings are conicle like the front ones.
I can do these rebuild kits for $125 each + postage for anyone interstate.
It includes all the bearings, seals and the collapsible spacer for the pinion.
