Gnaget Posted July 20, 2010 Report Share Posted July 20, 2010 Hello. Searched on the web but didn't find the answer so I ask here. I want to take a T50T tranny and put a T504A bellhousing on it so my KE11 tailshaft fits bolt on. Is there something I must change on the box or is it just to switch over and go ? Thanks Quote Link to comment Share on other sites More sharing options...
mikey_m Posted July 27, 2010 Report Share Posted July 27, 2010 I have done the research and a mock bolt up and it seems to work. I have an AE71 and have this worked out so I can run a T Series T50 behind the 4A Swap Bellhousing and Rear Housing for the shifter (Same bolts and Gaskets) Then use a KE70 Tailshaft to matchup the new rear output shaft on the Tseries T50 Quote Link to comment Share on other sites More sharing options...
tojo2 Posted July 29, 2010 Report Share Posted July 29, 2010 Hello. Searched on the web but didn't find the answer so I ask here. I want to take a T50T tranny and put a T504A bellhousing on it so my KE11 tailshaft fits bolt on. Is there something I must change on the box or is it just to switch over and go ? Thanks Pre 82 T- t50 like you want to use got smaler input bearing so you need a spacer to center it in the 4A-t50 bell. Should find some info on it if you search as its been mentioned a few times :) Quote Link to comment Share on other sites More sharing options...
AE25 Posted July 30, 2010 Report Share Posted July 30, 2010 Pre 82 T- t50 like you want to use got smaler input bearing so you need a spacer to center it in the 4A-t50 bell. Should find some info on it if you search as its been mentioned a few times :) 2nd that. theres no difference between a late T series T50 (ta61, te71 1983+) and the 4age T50. they are both 22spline and interchange. any 20 spline t50 has a smaller input shaft bearing that locates on the bellhousing.. which requires a locating ring to keep the gearbox concentric with the crank. Quote Link to comment Share on other sites More sharing options...
