July 25, 201016 yr comment_454330 Problem 1 Ok just wondered if this is normal, on the drivvers side there is a big gap between the body and the bumper while on the other side its sitting against the body. Just wanted to know why this is and if i can fix it, is the bumper bent somehow even though it doesnt look bent or is it to do with the mounts... Please help, see pictures below! My main concern is that when i put em on my ke55 thats been freshly resprayed it may damage the paint on the passenger side... Problem 2 When removing my rear bumper on my KE30 i undid all the bolts underneath but the bumper wouldnt budge then i noticed these bolts on the side and i have no idea how to get to them, any ideas? I tried gettin onto it from underneath but theres not enough room between the body and the bumper to get any tools in there... Please help, see pics below! These bolts... Thanks... Report
July 25, 201016 yr comment_454332 looks like the mounts need to have a little shunt back the other way mate. Report
July 25, 201016 yr comment_454352 for problem 1. losen the 12mm nuts on the inside of bumper bracket and adjust accordingly problem 2 open the boot 3 bolts down the bottom 1 for braket 2 for rubber piece of crap Report
July 25, 201016 yr comment_454356 If one side of the front bumper is closer than the other that means the brackets are bent, are the brackets 90 degrees to the bumper? Report
July 25, 201016 yr comment_454399 The bolts in the rear bumper are in the boot, under the vinyl/fibre sound deadening. 10mm socket or spanner will take care of them :yes: Report
