InTrenches Posted August 6, 2010 Report Share Posted August 6, 2010 So I got defected for my coilovers, I can't find any good condition stock struts anywhere. My friend has some ke70 ones. Will they fit? I need an answer asap thanks Quote Link to comment Share on other sites More sharing options...
philbey Posted August 6, 2010 Report Share Posted August 6, 2010 Hmm, this is the DTEI stance on coilovers. I should get my CPE I can write a nice little report and charge people 500 bucks for it! Aftermarket Suspension Units Aftermarket front and rear suspension units are available that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle’s suspension height to be varied. The adjusting of the threaded spring saddle varies the lower position of the spring and therefore, the vehicle ride height, but does not alter the amount of suspension travel. These are commonly known as coil overs. For these units to be an acceptable alternative to the original manufacturer’s suspension, they must meet the following criteria. They must: - have at least two thirds of the amount of suspension travel of the original suspension system fitted by the manufacturer of the vehicle - have a rubber or other resilient bump stop to limit travel to ensure there is clearance between the coils when the suspension is at full bump - incorporate a permanent locking device on the adjustment mechanism to prevent the adjusting of the suspension that results in the vehicle’s ride being less than that minimum legal height specified for that vehicle. Verification of the above must be in the form of a report from a Chartered Professional Engineer (CPE). The report must specify the measured suspension travel of both the Original Equipment Manufacturer (OEM) suspension arrangement and that of the aftermarket replacement. On receipt of an acceptable engineering report by Vehicle Standards, a Statement of Requirements will be sent to the owner detailing the modifications and any applicable conditions and the vehicle would be required to pass a roadworthiness inspection. Vehicle Standards has a comprehensive list of minimum suspension heights for the majority of vehicles and can be contacted on 1300 882 248. Quote Link to comment Share on other sites More sharing options...
InTrenches Posted August 6, 2010 Author Report Share Posted August 6, 2010 Hmm, this is the DTEI stance on coilovers. I should get my CPE I can write a nice little report and charge people 500 bucks for it! Aftermarket Suspension Units Aftermarket front and rear suspension units are available that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle’s suspension height to be varied. The adjusting of the threaded spring saddle varies the lower position of the spring and therefore, the vehicle ride height, but does not alter the amount of suspension travel. These are commonly known as coil overs. For these units to be an acceptable alternative to the original manufacturer’s suspension, they must meet the following criteria. They must: - have at least two thirds of the amount of suspension travel of the original suspension system fitted by the manufacturer of the vehicle - have a rubber or other resilient bump stop to limit travel to ensure there is clearance between the coils when the suspension is at full bump Sorry I worded my question poorly. Will ke70 stock struts fit into a ke30? And is it legal? - incorporate a permanent locking device on the adjustment mechanism to prevent the adjusting of the suspension that results in the vehicle’s ride being less than that minimum legal height specified for that vehicle. Verification of the above must be in the form of a report from a Chartered Professional Engineer (CPE). The report must specify the measured suspension travel of both the Original Equipment Manufacturer (OEM) suspension arrangement and that of the aftermarket replacement. On receipt of an acceptable engineering report by Vehicle Standards, a Statement of Requirements will be sent to the owner detailing the modifications and any applicable conditions and the vehicle would be required to pass a roadworthiness inspection. Vehicle Standards has a comprehensive list of minimum suspension heights for the majority of vehicles and can be contacted on 1300 882 248. Quote Link to comment Share on other sites More sharing options...
ke70dave Posted August 6, 2010 Report Share Posted August 6, 2010 yeah apparnetly he didnt get defected for the coilovers, he got done for the the car being too low. ive been trying to find information like that that is applicable in queensland. not having much luck.... thats interesting about the permanent locking thing that doesnt allow you to go lower than legal height. one way of doing it i guess. though i belive that there are a few "coilover" companies around that are considered ADR approved (places like fulcrum sell TEIN coilovers) and i wonder if they have that permanent limiter thing on them. ive discovered that trying to find what is legal and what isnt, is a complete pain in the ass. Quote Link to comment Share on other sites More sharing options...
InTrenches Posted August 6, 2010 Author Report Share Posted August 6, 2010 yeah apparnetly he didnt get defected for the coilovers, he got done for the the car being too low. ive been trying to find information like that that is applicable in queensland. not having much luck.... thats interesting about the permanent locking thing that doesnt allow you to go lower than legal height. one way of doing it i guess. though i belive that there are a few "coilover" companies around that are considered ADR approved (places like fulcrum sell TEIN coilovers) and i wonder if they have that permanent limiter thing on them. ive discovered that trying to find what is legal and what isnt, is a complete pain in the ass. If anyone has an answer for me please post. Quote Link to comment Share on other sites More sharing options...
towe001 Posted August 6, 2010 Report Share Posted August 6, 2010 Yes they will. But you will have to change the top hats over. Thats the part that bolts the strut to the body Quote Link to comment Share on other sites More sharing options...
InTrenches Posted August 9, 2010 Author Report Share Posted August 9, 2010 thanks a lot Quote Link to comment Share on other sites More sharing options...
rad32 Posted December 21, 2010 Report Share Posted December 21, 2010 just to confirm. i can use ke70 coilovers in my ke30? just change the top hats? cheers Quote Link to comment Share on other sites More sharing options...
BUZ440 Posted December 21, 2010 Report Share Posted December 21, 2010 toyota carona coil overs with camber and caster kit part number #760916 k macs i have these in my ke30 Quote Link to comment Share on other sites More sharing options...
rad32 Posted December 22, 2010 Report Share Posted December 22, 2010 i am buying a set of ke70 coilovers already. just wanna know if they will fit or not!? Quote Link to comment Share on other sites More sharing options...
Crowie55 Posted December 22, 2010 Report Share Posted December 22, 2010 i am buying a set of ke70 coilovers already. just wanna know if they will fit or not!? Change the top hat over to the original factory one, and you should be right. Quote Link to comment Share on other sites More sharing options...
