Easiest Engine Swap To Ke10
Hi there. Just startting on my KE10 projekt in to wich i want to put a bigger engine. What is the easiest swap possible? Engien and tranny wise.
Dead right- Start looking for the best one you can find Finn, and grab a few mods like carb/extractors off here while you wait to get a good one.
Where are you located? Got any pictures of the ke10?
5k/5 speed with side draft weber's and extractors would be nice.
Finland. The southwestern area to be exact. I have had tis car for about 5 years and managed to paint it, but then then there was a little conflikt with the onvwer of the garage so it has now been standing outside for about 4 yeas.
All of the K series engines will fit K 2K 3K 4K 5K and 7K.
The 7K is the biggest and most modern.
That's about the limit of it. You can fit other gearboxes to K engines though, as there are some adaptor bellhousings that allow you to do this (so you can upgrade the Box to the tougher T or K series boxes)
Keep in mind the 7K is physically bigger and requires some mods to fit. Plus it is not that easy to find one.
