tojo2 Posted August 26, 2010 Report Share Posted August 26, 2010 (edited) 75 w gear oil is about the same viscosity as 10 w motor oil http://www.bobistheoilguy.com/cms/index.ph...8&Itemid=55 Edited August 26, 2010 by tojo2 Quote Link to comment Share on other sites More sharing options...
Trev Posted August 26, 2010 Report Share Posted August 26, 2010 So you are saying that a 40 weight is thicker then a 80-90? If it is using oil then try Penrite HPR50. 75 w gear oil is about the same viscosity as 10 w motor oil http://www.bobistheoilguy.com/cms/index.ph...8&Itemid=55 FFS, some of you c**ts annoy me, did I say 40 weight is thicker then 80-90 weight or 80-90? I said so you are saying that you think 40weight is thicker then 80-90 gear oil which if you look at the chart it isn't until it heats up. Quote Link to comment Share on other sites More sharing options...
Trev Posted August 27, 2010 Report Share Posted August 27, 2010 http://www.rollaclub.com/board/index.php?showtopic=44418 Quote Link to comment Share on other sites More sharing options...
GJM85 Posted August 27, 2010 Report Share Posted August 27, 2010 If your looking for a solid oil that minimized smoke but still gives a relatively good visc rating Gulf Western Engine Extender is the shit... 25w60 Quote Link to comment Share on other sites More sharing options...
