September 1, 201016 yr comment_464702 hi all i heard a ke20/25 diff fits straight into a ke17 is this true? if not does the centre atleast fit ? any help would be much appreciated cheers Report
June 18, 201115 yr comment_533026 did you ever get this sorted. i'm looking at same thing thanks, terry Report
June 18, 201115 yr comment_533058 It wont go straight in, well into a ke10 anyway, you need to move mounts Report
June 18, 201115 yr comment_533074 You really need to look at the wheel track of the vehicles. If the wheel track is wider in the rear then you can guarentee the spring mounds will be wider, which is one problem. The shock absorber mounts on the diff is the other problem. I was caught by a rumour that ke55 diffs bolt straight into ke20's. Not so. Report
