Ae86 Coilovers
just simply, will ae86 coilovers fit into a rt142 corona. like are the two bolts that connect to the knuckle on the lca the same. or what do i need to do to put ae86 coilovers in. i will change the hats to suit aswell.
thank you in advance to any help.
cheers :)
Andrew.
Edited by theketokid
you sure about that destroyer?
I thought rt142 were the same bolt pattern.
could someone maybe measure the distance between the bolt holes and i will aswell?
alright, i measured the bottom of struts, they were 90mm centre to centre on the two bolts.
What struts?
