September 27, 201016 yr comment_471862 hello peoples just fitted a t series diff out of a ta22 i think, well pretty sure anyway into my ke30 2dr, i have previously fitted a ke55 tailshaft, huge compared to a ke30 tailshaft anyhow after fitting the diff i realised the tailshaft needed to be shortened because the t series center is longer (SPEWIN) so getting it shortened tomorrow for $120. don't know why this happened, i thought all u have to do is swap brackets, mounts etc?? any1 come acrosss this issue? Report
September 27, 201015 yr comment_471944 hello peoples just fitted a t series diff out of a ta22 i think, well pretty sure anyway into my ke30 2dr, i have previously fitted a ke55 tailshaft, huge compared to a ke30 tailshaft anyhow after fitting the diff i realised the tailshaft needed to be shortened because the t series center is longer (SPEWIN) so getting it shortened tomorrow for $120. don't know why this happened, i thought all u have to do is swap brackets, mounts etc?? any1 come acrosss this issue? Yes, T series diffs are longer and need a shorter driveshaft. Check your driveshaft flange if it fits the T diff :wink: If not, find one that does before you shorten.. Report
September 27, 201015 yr comment_471960 don't know why this happened, i thought all u have to do is swap brackets, mounts etc?? any1 come acrosss this issue? Assumption, the mother of all feck ups. As mentioned, the T series being a front loader diff, the snout will be longer. Report
September 27, 201015 yr Author comment_471962 lol so tru what tailshaft would not need shortening? Report
September 27, 201015 yr comment_471978 lol so tru what tailshaft would not need shortening? doubt it will help you but some of the Te37s had T-diffs.. don't think any other shafts will be a direct fit Report
September 28, 201015 yr comment_472000 In a Corolla Trueno service book I've got, the length of the tail shaft is shorter for the T-series diff. Report
September 28, 201015 yr Author comment_472004 thanks guys ill look into it, bloody good blokes u are lol cheers. Report
