Looking at the ECU plugs (smallest on left) it will be in the middle plug on the top row 2nd from the left, you are also better off taking the case off and seeing if it is in that location as stated on the board.
EDIT: What Justin said :laff:
Edited by Trev
can't remember on an ae82, either bottom of the dash above the tunnel (in the middle) or in the passenger side kick panel..
On top of the tunnel, up against the firewall.
Hard to get to?,what has to be removed to get to it
Not for me, maybe doing it your 1st time though.
Need to remove the cubby hole (front enclosed console), undo the 4 nuts and pull it out.
If you need photo's just let me know.
