GBKE15 Posted September 12, 2005 Report Posted September 12, 2005 (edited) I have just about finished the 3k swap into my ke15 and am looking at the nect project. I purchased some late model celica gt wheels that are the 4x114.3 pattern and am trying to figure out what the easiest thing to do would be. Is there a different axle that I can swap in for the rear or should I just get rid of the celica wheels and go with the 4x110 pattern. The front seems to be an easy solution. What have you guys done on the rear?? Thanks in advance. Edited September 12, 2005 by GBKE15 Quote
Felix Posted September 13, 2005 Report Posted September 13, 2005 i have considered doing this with my ke15, but thought it isn't really worth the effort. there is no simple bolt in option. i have retained the standard stud pattern, and simply gone to mazda 13x5.5" steel rims, as they fit the car perfectly and allow me to run decent performance tyres in 185/60r13. yea, the front is easy. just bolt on later hubs. the back is a different story. you could adapt a ke20 diff housing as it is the next narrowest housing, and do a ke30 axle swap (need to trim each axle splined end about 3mm) to that to get your 4x114.3. the only problem is that it will be about 50mm wider which will limit wheel selection, unless you want to start flaring guards. doing the above swap won't make any difference strengthwise, you just end up with bigger self adusting drums and your 4x114.3. also you will need to fiddle around with handbrake cables and moving diff mounts. maybe look into getting your existing axles and drums redrilled? maybe you could investigate a rear axle from a datsun 1200, or 120y or something, to get the right width? other than that you could look at something stronger and get it narrowed. but that is a bit overkill for a 3k. Quote
mikeys toy[RL] Posted September 13, 2005 Report Posted September 13, 2005 i put a te28 rear in my ke18 :n: but you guys don't have te28's........maybe celica? Quote
Felix Posted September 13, 2005 Report Posted September 13, 2005 how much wider is it? how do you go with scrubbing with a load on? Quote
mikeys toy[RL] Posted September 13, 2005 Report Posted September 13, 2005 ke18 springs are wayyyy stiff, with 185/70r13s they will rub slightly on a hard bump loaded theyr'e only about 25mm wider total Quote
Felix Posted September 13, 2005 Report Posted September 13, 2005 (edited) ok, not to much wider. i run the same wheel/tyre combo on both the ke15 and ke16. neither has a problem with scrubbing. even when fully loaded. i agree, the wagon springs are a LOT harder. it doesn't handle anywhere as well as the ke15 in the rear. having a load on board helps a lot. Edited September 13, 2005 by Felix Quote
Super Jamie Posted September 13, 2005 Report Posted September 13, 2005 sell the celica wheels, buy some mazda wheels from ausrotary.com or the wreckers Quote
mikeys toy[RL] Posted September 14, 2005 Report Posted September 14, 2005 way back when i was running '85 rx-7 wheels Quote
GBKE15 Posted September 15, 2005 Author Report Posted September 15, 2005 Mikey, You're out in the midwest(US), right? What's a te28? I'm still trying to figure out all of the model designations. It's on my to do list to find the mazda wheels, I just really liked the look of these celica wheels. Thanks again. Glenn Quote
mikeys toy[RL] Posted September 17, 2005 Report Posted September 17, 2005 te28 is a '74 corolla 2tc 2dr (only ones we ever got) wagon Quote
GBKE15 Posted September 26, 2005 Author Report Posted September 26, 2005 RIGHT THEN! Looks like I have aquired a set of rx-7 wheels. We'll see how long it takes to get them. Now, what is the largest tire that I can run with the stock setup on a ke15, I have two sets of 225/45/13 hoosiers that are free if they fit. Is this even a slight possibility? Thanks, Glenn Quote
Super Jamie Posted September 26, 2005 Report Posted September 26, 2005 probably 185s on the front, maybe 205s if the wheels are the right offset, but i doubt it on a ke1x, there's not much room there there's usually a bit of room under the back, i'd expect 205 or 225s if the wheels are a good offset. you can also space the leaves in 5-10mm for a bit more space Quote
Redwarf Posted September 26, 2005 Report Posted September 26, 2005 Doug can probably confirm completely, but I think Jamie's right, 185's are about the biggest. If they're early RX7 wheels, they'll only be 5.5" wheels, and 225's wont go on them anyway. R Quote
GBKE15 Posted September 26, 2005 Author Report Posted September 26, 2005 It figures, with two full sets of streetable tires sitting here staring me in the face that they wouldn't fit. I guess it's par for the course. When I get the rims I'll check it out. I thought they were wider originally to fit the tires. They are early rx7 wheels 81-83. This board rocks!!!!!!!!!!!!!!!! Thanks again, Glenn Quote
Super Jamie Posted September 27, 2005 Report Posted September 27, 2005 (edited) you'll also find that fitting tyres larger than 185 to a corolla is counterproductive to wet weather handling. they're only light, so you give them a big footprint and they have a tendancy to aquaplane alot more on a little 10, you could even get away with 165 cheesecutters, especially if you're leaving the rest of the car stock with venetians and whatever. gives it a nice "grandpa's old stocker" sort of look the correct sizes for ke10 speedo accuracy are 185/60/13 and 165/70/13 (good point about 5.5" wheels too, i didn't even think of that) Edited September 27, 2005 by Super Jamie Quote
