fkj Posted November 13, 2010 Report Posted November 13, 2010 The bottom of each side of the boot has rusted through, hole i can fit 4 fingers through. I got told fibreglassing is best, what would you think? Quote
ae95- wagon kid Posted November 13, 2010 Report Posted November 13, 2010 are you good at welding find someone who is and weld in some plate then skim it over with a good quality filler a and spray it you can fiberglass it but it will look like shit if you don't know what your doing just my 2 cents :happy: Harry Quote
fkj Posted November 13, 2010 Author Report Posted November 13, 2010 I know how to fibreglass, but can't weld for shit, + its right on the bottom side where its all rounded so i figured glassing would be easier. Quote
ae95- wagon kid Posted November 13, 2010 Report Posted November 13, 2010 if you can fiberglass then do it make sure you get ALL the rust out and rust inhibiter once its back to bare metal then fiberglass and spray good luck with it mate Quote
Spencer[RL] Posted November 16, 2010 Report Posted November 16, 2010 Had the same place fiberglass did the trick! Quote
ljmk2468 Posted November 16, 2010 Report Posted November 16, 2010 i just used fibrglass around my fuel filler... worked a treat, and for extra strength i threw some gorilla hair in with the bog. Quote
touge rolla Posted November 16, 2010 Report Posted November 16, 2010 i have fix so many dodge ups from people using fiberglass it will only make it worse later on i think if you are going to be bother fixing it do it properly. simply cut a square out where the rust is cut a peice of 1mm steel to the size and your local panel shop or even an engineering shop will weld it in for you they shouldnt charge anymore than $20. Quote
jimmy-d Posted November 18, 2010 Report Posted November 18, 2010 +1 for the above comment,I can weld and I can f/glass and for a long term solid rust free repair I would always recommend welding and what you spend now you will Know doubt save when it all starts to crack under flex etc which I can almost guarantee it will in time.I guess the real question is "how long your keeping it for",are you going to dolly it up for a quick sale or is it a keeper. Quote
fkj Posted November 25, 2010 Author Report Posted November 25, 2010 ive re-thought this, the car is a keeper, so I'm using metal :) Quote
