December 23, 201015 yr comment_490081 Hey just scored a fuel/boot release setup for my 70. I'm pretty confident about setting it up. Could someone with the same setup post up a few pics of how they are mounted? Especially the fuel one. Confident..... but a few pics never hurt. Also a measurement from the edge of the body to the centre of the fuel release mech hole would be awesome. don't want the fuel cap sticking out or in. Cheers as always! :y: Reed Edited December 23, 201015 yr by blzbub666 Report
December 23, 201015 yr comment_490083 dude the fuel release cable goes into the side were the stopper is, you just have to take out the stopper now and drill a hole into the side, were the stopper used to be :yes: if that makes sence and the boot realese cable is just as easy it runs along the D/S same as the fuel door realease cable and then up the right side of the boot and into the lock pics to follow gimme a minute or two Report
December 23, 201015 yr Author comment_490088 What I figured. I just don't wanna drill the hole wrong. No harm in getting it right first time! And the boot release runs to the lid! Never would of guessed that! Report
December 23, 201015 yr comment_490091 yeah man up the swing arm on the right hand side, then along the boot, hence the little tab looking things, then into the boot lock, Report
December 23, 201015 yr Author comment_490093 Crazy, did any *e7* come with a keyless fuel flap? Or will I have to weld over the one I have? Report
December 25, 201015 yr comment_490493 Crazy, did any *e7* come with a keyless fuel flap? Or will I have to weld over the one I have? They use both key and release lever man :) Report
December 26, 201015 yr comment_490553 Do I only need the cable to set up the fuel door release or is there more to it? Because I have the cable but I just can't see how it would work :hmm: Maybe someone could post a picture if it isn't too much trouble Report
December 26, 201015 yr comment_490568 Thanks blz, that helps alot. I though I was missing something, now there is more parts to add to the list for when I go to the wreckers Report
December 29, 201015 yr Author comment_491391 Where the expletive are the levers meant to mount? Figured it out, :y: Edited December 29, 201015 yr by blzbub666 Report
