Zaheer Posted December 30, 2010 Author Report Posted December 30, 2010 (edited) ahaan Thanks. Here i am able to find the new chrome ones(both front and back)local made for 40$. but there chrome isn't that good. Edited December 30, 2010 by Zaheer Quote
Zaheer Posted December 30, 2010 Author Report Posted December 30, 2010 One more thing, how i can repair my dash every thing is good with it except one corner you can see in marked area. suggestions are welcomed. Quote
Zaheer Posted January 3, 2011 Author Report Posted January 3, 2011 Progress on the weekend Saturday Progress – it was freaking cold there temp was near -1°C but still managed to work 1. Steering Rack changed - previous one was in very bad shape. 2. Steering arms reused. Both were in good condition 3. Lower Control arms changed 4. Front struts one of them changed because it was damaged. 5. Springs changed front/back previous ones were wielded 2 inch packing was placed. Now packing is removed and new springs in place 6. Shock absorbers are replaced. Day ended with washing engine bay, using degreasers and rest of the car cleaned up there was huge deposit of mud underneath. Sunday it was little bit dedicated for dash/ electrical started my work bit late 1. Opened the dash and there was huge amount of dust. 2. Tried to clean it up with air pressure but all in vain. Then used the paint brush and all done manually. Due to cold/bad light winded up my work just screwing back the parts. And found that there is some problem with indicators/ break switch/ hand break switch/ reverse light cause none of them working now….lol Now again have to wait for 5 office working days. Photos are on the way will be posting in a while. Quote
LittleRedSpirit Posted January 3, 2011 Report Posted January 3, 2011 Ah yes old wiring, do not get me started. It seems the more you mess with it, the less things work! :bash: Quote
Zaheer Posted January 3, 2011 Author Report Posted January 3, 2011 @LittleRedSpirit 100% Agreed with you. But here electricians are really annoying. they don't care about the clips just cut the wire rejoin and insulate with tape and continue to work. but i am trying to remove such joints. Quote
Zaheer Posted January 3, 2011 Author Report Posted January 3, 2011 Here you can see rust and grease Very Bad in condition Dash dust (ughh) Quote
JJT036 Posted January 4, 2011 Report Posted January 4, 2011 Man that's a lot of Dust in the Dash! Comin' along nicely man. Keep it up. :thumbsup: Josh :cool: Quote
Zaheer Posted January 6, 2011 Author Report Posted January 6, 2011 Tomorrow I am going to overhaul the engine. There is some noise in timing chain along with that i am going to replace rings and valves. If all goes well we will also change the clutch set(Clutch Plates, Pressure Plate and clutch bearing) Hope for the best. Quote
Zaheer Posted January 11, 2011 Author Report Posted January 11, 2011 Hi Guys, one important news. Motor is approximately ready today we will put it in. updates regarding the motor overhauling are on the way. will be posting them in a while. Quote
Zaheer Posted January 17, 2011 Author Report Posted January 17, 2011 Apologies for the delay. Photos when we started our work In Rocker arms Cover you can see that water and oil mixed in yellow color Block Assembly Pistons not in good shape 2 of them were quite rough from sides Quote
Zaheer Posted January 17, 2011 Author Report Posted January 17, 2011 Pistons were at standard size "0" Crank Shaft was already at "0.25" Moving toward head Valves were in very bad shape you can see in pics. Quote
B.L.Z.BUB Posted January 17, 2011 Report Posted January 17, 2011 Are you just gonna overhaul the engine or give it a bit more grunt? Quote
Zaheer Posted January 17, 2011 Author Report Posted January 17, 2011 Few other photos of crank, pistons and head while washing Engine Water body, its bearing was also making some noise. Quote
Zaheer Posted January 17, 2011 Author Report Posted January 17, 2011 @blzbub666 For the time being I am just overhauling it. Quote
Zaheer Posted January 17, 2011 Author Report Posted January 17, 2011 Few other dirty parts. Engine mount was very weak. Cam Shaft was in good shape Greasey uhhhh Starter Motor Quote
