benhachi Posted January 16, 2011 Report Posted January 16, 2011 Hi guys, I'm in the middle of doing an engine conversion in my KE20, I'm putting in a 2TGEU with a 3T bottom end. I've got the engine sitting in the car but I've ran into a problem where the brake master cylinder is too long and is in the way of the twin carbies. Does anyone know of any shorter brake master cylinders I can use? Maybe Datsun? Cheers, Ben Quote
Mick E Posted January 16, 2011 Report Posted January 16, 2011 you need a te-27 pedal box to move booster so mcyl is aganist strut tower, to clear carbys Quote
benhachi Posted January 16, 2011 Author Report Posted January 16, 2011 Where would be a good place to source a te-27 pedal box? Quote
Redwarf Posted January 16, 2011 Report Posted January 16, 2011 (edited) I got mine through importmonster.com.au. Note: It's not bolt in. Some fabrication required. http://www.rollaclub.com/board/topic/7663-redwarf-rebuild-v40/page__st__30 Edited January 16, 2011 by Redwarf Quote
benhachi Posted January 16, 2011 Author Report Posted January 16, 2011 I got mine through importmonster.com.au. Note: It's not bolt in. Some fabrication required. http://www.rollaclub.com/board/topic/7663-redwarf-rebuild-v40/page__st__30 Cheers for that Redwarf. Appreciated. Quote
