January 26, 201115 yr comment_498467 hey guys I'm building a charged 5k hopinng for power 100kw realisticly 80kw lol and want to know what gear box to use that will handle punishment i have both k40 and k50 any suggestions? thanks Report
January 26, 201115 yr comment_498473 http://www.rollaclub.com/faq/index.php?title=Tech:Engine/K_Series/Gearboxes theres a couple of options Report
January 26, 201115 yr Author comment_498485 thanks for that help looks like i have some work to do :) Report
January 26, 201115 yr comment_498487 what are you doing about diff? stock one wont last long lol Report
January 26, 201115 yr Author comment_498494 going welded 4.3 one standard in my ke70 till it breaks then either t series or an r31 diff thats the plan so far I'm on bit of a tight budget first year wages lol Report
January 27, 201115 yr comment_498577 Well if you're one of these tools who think a big man drops the clutch at 5000rpm and smokes the tyres in curcular burnouts then the diff won't last. However if you always have the car rolling before you floor it you will be surprised how long a stock diff can last. Its the shock loading that snaps axles and strps teeth off gears, and if you weld the diff you will overload other components even more. Run stock stuff an treat it intelligently until you have the T stuff ready. Keep an eye on the weight of the diff too, as the heavier it is the greater the weight flailing around ruining the handling in the back. Report
January 27, 201115 yr comment_498585 mmmmm, I'll second the above. If driven properly (not abused) stock stuff will last a long time. Run your k series box and see if it does break. I wasnt making huge power out of my 5k's but they were healthier than stock and even with motorsport use, stock stuff used to last. In 15 years or so, I only ever broke on box and that was due to stupidity - slotting first gear while doing 50km/h. Even this left the box still drivable. Welded diffs used to last me a couple of years, think I replaced 4 or so over the years. Another example of supposedly week gearboxes is my uncles FX Holden. The Opel gearbox that was fitted, not known for its strength, outlasted two well modified 202's. A gearbox article in Steet Machine years ago summed it up perfectly. Quote "If you keep breaking gearboxes, do yourself a favour and by an auto....." Report
January 27, 201115 yr Author comment_498665 i know what you guys are saying and i don't think they will last long the clutch will be dropped at 5thou revs and be given a hard time often i am building it for drifting and track days stil got a while till its going anyhow see what happens and how the funds are at the time :P Report
January 27, 201115 yr comment_498719 Trackwork isn't that hard on a driveline once you've got it off the line. Run cheap stuff and put all your money into getting it handling well. There's no better fun in life than taking a cheap small car and beating someone in a big expensive one!! Report
